Opinion On The Wear On This Clutch Setup
Ok i finally pulled the side cover off this banshee i just got, which has a clutch that slips after 3rd gear mainly, i want some opinions on the wear on the inner and outter hub and some of the other stuff before i start trying to replace stuff, another member on here has a real good deal on some stuff id like to buy, the fibers and plates i wanted to take a micrometer to but i couldnt find it I discovered the billet impellar and the moose basket when i took it apart, the clutch dampners were completely crapped also it looked, thanks for any help, my first banshee.
Edited by ATVRidinManiac
Clutch is toast. That brown shit on the hub is a pretty dead give away. The basket looks good. Bushings are cheap. A new hub and pressure plate are cheap too just in case they are warped. If your getting the one from wacko just buy it before it's gone. It has a pancake bearing which is a must have, and new hub and pressure plate, and what I believe is a fast clutch.
