toytech Posted August 9, 2012 Report Share Posted August 9, 2012 is the only thing different from the early cdi to the newer ci the plug design? can I change the connector and put a new style on our 87? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 9, 2012 Report Share Posted August 9, 2012 This has been covered in the past, you should use the search. Supposedly some years have different timing curves. But if you change the plug AND the terminals in the plug on the wires, you can use it. The wire terminals inside the plugs are different between early style plugs and late style plugs. Also, if it is a 1997 or newer CDI, it will have the park brake rev limiter in it which means that you will have to make sure that the Green/Yellow wire never touches ground. Quote Link to comment Share on other sites More sharing options...
toytech Posted August 9, 2012 Author Report Share Posted August 9, 2012 This has been covered in the past, you should use the search. Supposedly some years have different timing curves. But if you change the plug AND the terminals in the plug on the wires, you can use it. The wire terminals inside the plugs are different between early style plugs and late style plugs. Also, if it is a 1997 or newer CDI, it will have the park brake rev limiter in it which means that you will have to make sure that the Green/Yellow wire never touches ground. thankyou I tried to seach, I found 2 topics on this, when I tried to open them I was denied access. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 10, 2012 Report Share Posted August 10, 2012 Search on here is not very good BUT if you use google, type in what you want to search for and then add "bansheehq" to it you should get better results. Quote Link to comment Share on other sites More sharing options...
