no spark,then spark?
92 shee
Trying to figure this problem out got a 92 banshee,stock carbs,tors removed with carb caps and idle kit,wiring is stripped down to bare minimum,just has key switch to turn on and off,so when key is on machine will start and run for about couple of seconds and then dies,go to start it back up and nothing,check spark and nothing,i traced it to the cdi box, i take the cdi box off of the frame and tap the cdi box with my hand and then i have spark again? could the cdi box be defective,i checked the gap between the stator and pickup its within spec( business card),checked the whole harness its good,i dont have a ohms meter to check out the stator,pickup,coil and other electrical parts,are the aftermarket adjustible cdi boxes anygood?
Thanks for your help Eric....
