Dahl87banshee Posted August 7, 2012 Report Share Posted August 7, 2012 Once and a while it will spark but not very often. I have checked the pick up gap and wiring connections. I am thinking its the coil but I have been wrong before. Any help would be appreciated. Also looking for a coil and possibly a stator, but I'll make a wanted add for that. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted August 8, 2012 Report Share Posted August 8, 2012 My key switch when bad. Have you considered stripping down the harness to the minimum? Clean your ground too. Use a ohm meter and search for the specs on the stator and test it too. Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted August 8, 2012 Author Report Share Posted August 8, 2012 Yeah it's already trimmed down to nothing. No extra wires hanging and lights go on when it starts. I think I'm going to make a new wiring harness off this diagram (already did last year but I'll make another one and try it) Hopefully it works. Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted August 8, 2012 Report Share Posted August 8, 2012 Use a ohm meter and search for the specs on the stator and test it too. Quote Link to comment Share on other sites More sharing options...
thomas h. Posted August 8, 2012 Report Share Posted August 8, 2012 The stator has a separate coil for lights which is not a test indicator for good stator. Bypass the kill switch maybe it is interminably contacting Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 8, 2012 Report Share Posted August 8, 2012 You check to make sure your flywheel is stil on? A sheered key can cause the flywheel to come off the tapered end and then not be press fit to spin when the motor cranks over... Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted August 8, 2012 Author Report Share Posted August 8, 2012 Yeah checked the flywheel key too, that was my first guess. And I don't have the kill switch, just a tether. Already tried bypassing it. It's kinda weird I get a little spark with the tether taken out but none with it in. Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted August 8, 2012 Author Report Share Posted August 8, 2012 Got it going. Put a new end on the orange wire for the coil and grounded a wire that had been ripped off and shee fired right up Quote Link to comment Share on other sites More sharing options...
