421 cub gas or racing gas
Whats the main gains/differences between race gas over pump. Ik u get more conpression,timing, and horsepower Ive heard u should not evn run the cub if its not on race gas.
i think most of it is for higher comp and timing i havnt ever seen a cub on pump but its possible
I think I've been told that the cubs need the compression and timing or they are way doggy on the bottom. If a person wants to run pump probably be better off running a serval. I'm sure somebody smarter than me will correct me if I'm wrong.
Yaaa that seems to be making the most logic to me as well. Im def gonna have to spend the extra cash n get the race gas. Especially since ill be duning the cubb.
If you're more into the duning than the drag I'd look into the serval. I've talked to a few guys with cubs and ported cubs that wish they would've went that way.
Good looks for the heads up. I cant try either never rode either cylinder. My thoughts are if u want low-end n a smooth power band u should build a 4 stroke then. Jus my 2cents
serval has more low end then cub. cub pretty much no low end
you can run pump gas in your cub, wont be as snappy in deep sand or whatnot
race gas will wake it up a good bit, or even better try some methanol... :drool:
depending on what you want to do with your cub, keep in mind a lot of timing and compression will make it run a lot warmer too.
Edited by Hilarious
Im actually gonna try a 10 cub on pump gas. I dont care about having doggy bottom end. Im used to it on my pump gas 350 drag ported that i dune. That thing is doggy in the deep sand on bottom. And i ride it no problem. I love the light switch feel. We ride banshees remember. Im sure your 421 and definetly my 465 on pump will have more bottom end torque them a 350 dragported on pump. I just want a fast duner. And the serval is not for me. I have rode one!
Thanks for the engine temperature pointer-hilarious. Possum we think exactly alike, thats the reason we ride banshees that violent power. That is exactly what im looking for. If i wanted something with grunt id ride a 4 mil n hook that up. Ive never rode either cylinder, so i cant compare at all but im just trying to imagine what the cub and serval would be like!!
Thanks for the advice. My banshees engine is bone stock all i did was throw shearers on, (because of intentions on building a motor) k&n pods and 300 main jets in. The bike has minimal bottom end but arm yanking top end. i actually enjoy riding it. Ive been told the cub's bottom end would actually be improved over my set up now. If thats the case id be very pleased.
