jimbo1986 Posted August 5, 2012 Report Share Posted August 5, 2012 Got serval running new carbs well everything was running right but i went to ride it for the first time and now it dosnt want run at all and when it does it only fires one side then it will fire both wtf is going on? Quote Link to comment Share on other sites More sharing options...
mike0chek Posted August 5, 2012 Report Share Posted August 5, 2012 first thing you prob wanna check is if your getting good spark. Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted August 5, 2012 Report Share Posted August 5, 2012 Good compression? Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 5, 2012 Author Report Share Posted August 5, 2012 The spark plug are new and it has a bright blue spark and compression is fine. Now today i went out and it fired up on both but then started acting up. One other thing is it would sit there and idle but if u gave to gas it shut off and yes all of tors system is removed? someone help i wanna ride this thing!! Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted August 5, 2012 Report Share Posted August 5, 2012 maybe cdi is going bad Quote Link to comment Share on other sites More sharing options...
thomas h. Posted August 5, 2012 Report Share Posted August 5, 2012 Sound like maybe float levels and carb sync. When's the last time you got new spark plug caps. I like to add die Eletric grease in my cap on both sides to help them last longer. Going back to your issue did you swap plug sides? Can you try to drive it around and the issue cleans up? Several times one of my carbs after sitting will leak fuel in one side. So I have to tow it to start it up. Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 6, 2012 Author Report Share Posted August 6, 2012 Ive tryed everything tested all the wiring but now thinking its the carbs but there brand new and were working good last time i started it. I am thinking its cursed any ideas im pissed Quote Link to comment Share on other sites More sharing options...
toytech Posted August 6, 2012 Report Share Posted August 6, 2012 moving carbs around stirs crap up, clean them, and check screens in the tank if you still have them. calm down bad things happen when your pissed. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted August 6, 2012 Report Share Posted August 6, 2012 i had a similar problem. take the reeds out and clean them real good. make sure they seal well. get all new reed gaskets when u do this, people have blown up new topends from using old reed gaskets. then make sure the choke tube is in place. are the slides in the right direction? the cut piece should be towards the air filter Quote Link to comment Share on other sites More sharing options...
thomas h. Posted August 6, 2012 Report Share Posted August 6, 2012 Choke tube? New carbs Maybe metal shaving Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted August 6, 2012 Report Share Posted August 6, 2012 Choke tube? New carbs Maybe metal shaving the small hose between the carbs. when u pull the choke it makes the other carb choke too. he did say new carbs, but i didnt know if he went with stock or... but its somethin to look for Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 7, 2012 Author Report Share Posted August 7, 2012 Well the carbs are tm34mm muniki carbs and yes the reeds and gaskets are all new. The problem all started when i changed the main jet by screwing the bottom cap like ive done with a hundred times and i dont see y this would do anything. After i put the new jets in it didnt want to start and when it did well i told u the rest of the story already. also i have plige petcock so i know its not that. Any ideas???? Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 8, 2012 Author Report Share Posted August 8, 2012 Any ideas??? Quote Link to comment Share on other sites More sharing options...
sootman73 Posted August 8, 2012 Report Share Posted August 8, 2012 Any ideas??? Have you set the floats at the right level? just because they are new doesn't mean they were set right, plus depending on your fueling needs they need set specific for each machine. are you getting good constant spark on both cylinders? Quote Link to comment Share on other sites More sharing options...
jimbo1986 Posted August 9, 2012 Author Report Share Posted August 9, 2012 How would u check for constant spark? Thanks i checked the bowl float level and set them right but its still wont run right. im outta ideas other than maybe cdi box or coil. Quote Link to comment Share on other sites More sharing options...
