Shifting mods
The other day i rode a well built banshee that made alot more power than mine and it shifted way smoother than my quad. He had a lockup clutch and short clutch lever and it was still easier to pull and to shift than my quad.
What mods do I need to do to my quad to get it shifting easily? I drag race alot and missing shifts is not an option anymore.
I plan on doing the shift star mod and adjusting the clutch. possibly replacing the clutch cable but i don't think it needs that.
(clutch is new FAST racing light duty)
If all you do is drag race, then go get yourself an override. If you do other riding mixed with drag racing, then do the following:
side-cut your gears
shift star mod
shift pro kit (but keep the heavier stock spring, don't use the shift-pro spring)
shift shaft mod
2nd bearing on the shift drum
Try that and see how you like it.
-Jared
And buy a new clutch cable.
I agree.
Since you would have to split your cases to get the gears side-cut, you might as well replace the clutch actuator arm bearing that's pressed into the cases, get the new clutch cable Windy suggested, and get yourself a nice clutch lever like an ASV.
-Jared
side-cut your gears
shift star mod
shift shaft mod
-Jared
Everything in this list, ^ he can do for you
I searched for the shift shaft mod but couldn't get a clear understanding of it. Is there a write-up to explain it?
Jared can i source the Shift-Pro kit through you? PM me a price if you stock them.
I think it has a lighter spring. I think that it doesnt help and is not recommend. But maybe ask around.
Hey man, I'm just an average joe rider like most on here. I would say give Kevin @ HJR a call, he can hook you up with the shift pro kit. You can also get it from cascadeinnovations.net
  • 2 months later...
Wow finally got my shift mods installed and took it for a test drive! holy shit this thing is fun to ride again! and neutral clicks in so easy that on the stand i don't even have to pull the clutch in!
Thanks guys for your help and damn i wish i woulda done this a long time ago!
