miami350 Posted August 3, 2012 Report Share Posted August 3, 2012 im haveing a problem my banshee keep braking the inner hub it brakes all the studs where the spring and screws goes at it brake all them Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 3, 2012 Report Share Posted August 3, 2012 So stop fucking tightening it so much. Do you have a clymers? Quote Link to comment Share on other sites More sharing options...
toytech Posted August 3, 2012 Report Share Posted August 3, 2012 are they breaking when you put it together ? or after you ride it? those bolts only tighten to 7 inche pounds. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 4, 2012 Report Share Posted August 4, 2012 The first banshee engine I ever built I broke two of them off because I tightened everything down like a monster-tard. Fail. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted August 4, 2012 Report Share Posted August 4, 2012 those bolts only tighten to 7 inche pounds. 7 FOOT lbs which works out to be 84 inch lbs. Quote Link to comment Share on other sites More sharing options...
toytech Posted August 4, 2012 Report Share Posted August 4, 2012 7 FOOT lbs which works out to be 84 inch lbs. you are correct. I must have had a brain fart when I posted oops. Quote Link to comment Share on other sites More sharing options...
