powder coated frame
kenny007
If you are in Chicago check out LoCo and Gorrila coating out south. Had them both coat stuff and it came out awesome. A lot of color choices including metallics. Gorilla did one banshee frame for a local guy nice metallic red like the yfz450r for $150 he told me. Came out great.
Edited by BIGONTS
its good to clean off to metal the coil adn all other grounds on the frame. also chase ALL the threads becore you put it back together. i use plugs in the holes to try adn help with that. mostly the heating causes some issues with the threads also.
i charge 250-350 depending on prep i have to do and color choices.
those flop colors are bad ass! you can also layer colors as long as they are a translucent, clear flake or candy type. dual layering solids is a waste of time.
The guys that did my pc put silicone in all the small threads and plugged the big ones. I didn't have to chase a single hole. They also did the frame and swingarm for under $300.c6e4d99f-8784-34cf.jpg
TON!
