still wont idle
27.5 pilots and 300 main 11/2 turn out still won't idle an pwer band kicks n half throttle second to third kick to crank an gas sometimes over flows what next? Carbs have been clean in an out
you can DL the manual below. You need the complete rebuilt kit for the banshee. This is the one that I used. http://www.ebay.com/itm/NEW-YAMAHA-BANSHEE-350-CARBURETOR-CARB-REBUILD-KITS-ALL-/370379947172?pt=Motors_ATV_Parts_Accessories&hash=item563c5d7ca4&vxp=mtr You should also check your float level and make sure that it is set between 18-22mm. It will all be explained in the manual. The jets in the kit all all worthless because they are for a stock machine.
Adam
