bansheeboi Posted August 1, 2012 Report Share Posted August 1, 2012 the crank gear nut back off the crank and made a groove in the case... the last pic is the oil pan that bloch is the shaving i clean out the case help guys what i need to do? the last pic is t Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 1, 2012 Report Share Posted August 1, 2012 Not torq'd to spec. If you torq the nut to spec it will stay right where its supposed to. It also looks like you are missing the locking washer that sits behind the nut. -Jared Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted August 2, 2012 Report Share Posted August 2, 2012 ^ yep. Quote Link to comment Share on other sites More sharing options...
bansheeboi Posted August 2, 2012 Author Report Share Posted August 2, 2012 Not torq'd to spec. If you torq the nut to spec it will stay right where its supposed to. It also looks like you are missing the locking washer that sits behind the nut. -Jared Ok thanks bro by the way do u have a fresh nut an the locking washer handy if so how much also u got a fresh gasket for the cover? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted August 2, 2012 Report Share Posted August 2, 2012 Ok thanks bro by the way do u have a fresh nut an the locking washer handy if so how much also u got a fresh gasket for the cover? cascade sells the washer and nut for just a few bucks and you can pick up the gasket from them as well. www.cascadeinnovations.net Quote Link to comment Share on other sites More sharing options...
