How Do I make My banshee faster
Here's a list of tools that every Banshee owner should own.
Flywheel puller
Impact driver
Compression gauge
Carb sync tool
Leakdown tester
Low pressure tire gauge
You can't make lots of power if you only have 100 lbs of compression.
You can't make it run right if you have an air leak or your carbs aren't synced.
While you're in there doing the timing plate, put in a TM Designworks case saver and replace the shift shaft seal. It's probably leaking. Inspect the front sprocket and replace if it's worn. Then replace the phillips head stator cover bolts with allen bolts.
