turbowrenchhead Posted March 23, 2013 Author Report Share Posted March 23, 2013 I'm going to try both dual and single carbs setups. The power band with the single hits really hard. Plus I have one cylinder buring richer then the other so I'm going to try dual carbs to see if I can balance that out a bit. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 24, 2013 Report Share Posted March 24, 2013 I'm going to try both dual and single carbs setups. The power band with the single hits really hard. Plus I have one cylinder buring richer then the other so I'm going to try dual carbs to see if I can balance that out a bit. Report back with results. My buddy had a 2/1 that kept burning odd like that on one side. No leaks or electrical issues. Quote Link to comment Share on other sites More sharing options...
Scrubtherubber Posted March 24, 2013 Report Share Posted March 24, 2013 i got a chariot setup with a 35 pwk airstryker and I love it so easy to tune, was dicking around with the 2 carbs for months then had enough switched to 1 and within the hour i was getting my arms ripped off Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 24, 2013 Report Share Posted March 24, 2013 Just imagine if you had one that flowed well....... Quote Link to comment Share on other sites More sharing options...
Scrubtherubber Posted March 25, 2013 Report Share Posted March 25, 2013 Seems to flow fine for me, see instead of spending my weekends tinkering for horsepower I spend my weekends riding Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted March 25, 2013 Author Report Share Posted March 25, 2013 I will report back with results. I'm thinking that I might have to jet one a bit richer then the other to balance them out. I bought a rebuild kit, idle screws, tors eliminator cable several main jets and a flow meter. I'm going with pod air filters for now till I get it dialed in and then go to a cfm air box if I like the dual over the single. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 25, 2013 Report Share Posted March 25, 2013 Seems to flow fine for me, see instead of spending my weekends tinkering for horsepower I spend my weekends riding Yeah it made it less complicated for you to tune now that there is just one carb. But there is still a TON of performance to be had in other 2/1 set ups. Both the trinity and chariot units are just garbage in my opinion. I like chariot but that piece isn't meant to perform, just make life easy for the newer tuners on trail type bikes. Just because it needed less tinkering doesn't mean it flows very well. Those choked out Billit intakes are why so many folks say they won't work. Quote Link to comment Share on other sites More sharing options...
Scrubtherubber Posted March 25, 2013 Report Share Posted March 25, 2013 it doesn't make life easy for "newer" tuners it makes life easy for all tuners. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 26, 2013 Report Share Posted March 26, 2013 I guess...... I can go through my PJ's about as fast as the guys on dirt bikes with one carb. Maybe it's all that practice. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted March 26, 2013 Report Share Posted March 26, 2013 I'm thinking that I might have to jet one a bit richer then the other to balance them out. Shouldn't have to do that. Something is wrong if you do. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted March 26, 2013 Author Report Share Posted March 26, 2013 Shouldn't have to do that. Something is wrong if you do. I imagine its my porting job. One is pulling a bit more air then the other. If I can get it to run good with dual's and slightly offset jetting then great. Quote Link to comment Share on other sites More sharing options...
possum Posted March 26, 2013 Report Share Posted March 26, 2013 ill never understand how tuning 2 carbs is hard. just as easy ae 1, just repeat the process on another carb. that makes 2 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted March 26, 2013 Report Share Posted March 26, 2013 ill never understand how tuning 2 carbs is hard. just as easy ae 1, just repeat the process on another carb. that makes 2 Agreed. Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted March 26, 2013 Author Report Share Posted March 26, 2013 I have the duals on now and I have been trying to tune them in. 370 and 360 were way to rich. I went to a 330 and 320, it is better, still seems rich. I moved the needle clip up two spots and now the RH w/ the 320 is backfiring. Backfire = too lean? Quote Link to comment Share on other sites More sharing options...
turbowrenchhead Posted March 26, 2013 Author Report Share Posted March 26, 2013 Round 3: I have 330 main's. 25 pilots needle on middle clip. No back fire now. Did a street run up to 3rd gear. The power band is much more smooth then the single carb. It still flutters at WOT. Its hard to tell if its rich or lean at WOT. I would have to guess a tad rich. I won't know untill I can do some WOT runs up to sixth and plug chop it. However I already like the way the dual's feel versus the single carb. Quote Link to comment Share on other sites More sharing options...
