inline coolers bigger the better...
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
I was thinkin to make a temp guage. I havent done this but want to,
Instead of useing anything with the hose. I want to use the exsisting Drain holes
on the cylinder s, with some type of auto aoto/cycle temp gauge. Then if you wanted you could run dual gauges for each side temp. Im not sure if the dual guages would work like that with the coolant flo and all. But I does seem like it would work since
there directly located on the cylinder and 1/2 inch from the sleeve.
It was just an Idea
  • 1 month later...
Heres how it looks with the radiator cover on.It really helps to channel the incoming air through the radiator instead of around it.I guarratee anyone with cooling issues will notice a difference,especially at lower speeds where you need all of the incoming air to pass through the radiator.
I'm running a similar temperature gauge block like Deuce,but I opted for an automotive style gauge.Its going on two years and it still works good despite the vibration.
The only time the needle vibs a bit is just off idle.The plastic does a good job of quelling the vibration.
