Engine help
Hey guys I need some advise my banshee I had a air leak from. Boost bottle and thought I had it fixed started it up one morning let it warm up and gave it one twist of the throttle and it sounded like it blew up running on one cylinder
So shut it off and was like fuck did compression test and it showed like 75 so figured it was fucked tonight took off reeds and cylinder looks fine and cylinder to
Took head off everything looks good now if I stil had that air leak would that throw my compression off cause I didn't test the other side it's not blown up everything looks good turns over good need some opinions
Thanks
Shouldn't as effect it that much if at all. We're you holding the throttle wide open and did you kick it til the needle stopped moving? I ask that cause that is some seriously low compression. Like you wouldn't be able to kick start that thing. I wonder if your compression tester went bad.......shoulda checked the other side too....
