joshp1214 Posted July 27, 2012 Report Share Posted July 27, 2012 Hi guys I just traded my 400ex for a 01 banshee it has just had the topend rebuilt and I'm not not sure long they have been on the but it has pro circuit full pipes. So here's my problem fuel runs out of the overflow tube on the right carbs pretty heavily when gas is on and I took it for a short 10 min. Ride and when I got back the inside of the right pipe was glowing red and smoking after the engine was shut off. I was told the carbs needed to be synchronized but it also seems it is running lean with the whole red pipe. Any suggestions would be appreciated Quote Link to comment Share on other sites More sharing options...
db25 Posted July 27, 2012 Report Share Posted July 27, 2012 What do you plugs look like..? And you mentioned it so I'm asking, are you carbs syned..? Quote Link to comment Share on other sites More sharing options...
joshp1214 Posted July 28, 2012 Author Report Share Posted July 28, 2012 Well I had my local builder check it out and the tube between the chokes was gone causing it to blow out air and run super rich. That problem has been fixed but my bottom end is terrible. The equalizer tube is missing would this cause the lack of bottom end power? Quote Link to comment Share on other sites More sharing options...
