2strokesonly Posted July 26, 2012 Report Share Posted July 26, 2012 (edited) Just got a 87 Shee it has new $200 reeds not sure what brand, silencer pipes and was bored 40 over, and the tors system is removed. I just had to rebuild the top end , bored to 60 over my question is how can I figure out what my jetting is set to so I can make sure its correct? Edited July 26, 2012 by 2strokesonly Quote Link to comment Share on other sites More sharing options...
do-work-son Posted July 26, 2012 Report Share Posted July 26, 2012 Just got a 87 Shee it has new $200 reeds not sure what brand, silencer pipes and was bored 40 over, and the tors system is removed. I just had to rebuild the top end , bored to 60 over my question is how can I figure out what my jetting is set to so I can make sure its correct? Take the bottom of the carbs off and look and the number on the side of the jets ... If its your first carb take your time it sounds scary but pretty easy once you do it I would take pics and notes Quote Link to comment Share on other sites More sharing options...
2strokesonly Posted August 14, 2012 Author Report Share Posted August 14, 2012 (edited) Take the bottom of the carbs off and look and the number on the side of the jets ... If its your first carb take your time it sounds scary but pretty easy once you do it I would take pics and notes thanks for the info it was easy. heres another one for ya. after the rebuild the shee ran like a raped ape then while still breaking it in it runs like its not getting fuel.." it boggs out" i changed the petcock cause mine was broke. it doesnt have the tors on it ither, changed the fuel lines and when i checked the jetting which was fine by the way i cleaned the jets with carb cleaner. cleaned the air filter and also got new gas too. it still does it and im thinking its the floats are stuck. how can i test this theory and would cleaning the carbs again with sea-foam help? thanks again for the help Edited August 14, 2012 by 2strokesonly Quote Link to comment Share on other sites More sharing options...
ATVridinMaNiAc Posted August 14, 2012 Report Share Posted August 14, 2012 Maybe check floats and float height, i just clean carbs with whatever carb cleaner i can get and use the little straw with it, my fav carb cleaner is Berkebile 2+2 gum cutter, and are the carbs synced? Quote Link to comment Share on other sites More sharing options...
2strokesonly Posted August 14, 2012 Author Report Share Posted August 14, 2012 yes the carbs are synced and i never had that problem before. could the float height change on me. without me even touching them? Quote Link to comment Share on other sites More sharing options...
