jimmymichael Posted July 24, 2012 Report Share Posted July 24, 2012 i resently got a 99 banshee it has 156 pounds of comp. cool heads boot bottle, fmf pipe stock gears and 20in back tires and my buddy has a 2000 all stock banshee well it has fmf header and yoshemira tail and it has more get and go than mine what do i need to do ???? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 25, 2012 Report Share Posted July 25, 2012 not a bad idea for you and your buddy to switch bikes and see what happens. Maybe he could tell the problem. But if he beats you on your bike, no problem. Quote Link to comment Share on other sites More sharing options...
Finch Posted July 25, 2012 Report Share Posted July 25, 2012 get better at shifting, first cheap mod is adjustable timing plate Quote Link to comment Share on other sites More sharing options...
db25 Posted July 25, 2012 Report Share Posted July 25, 2012 What does a adjustable timing plate cost Quote Link to comment Share on other sites More sharing options...
toytech Posted July 25, 2012 Report Share Posted July 25, 2012 What does a adjustable timing plate cost fast racing has them for $70.00 Quote Link to comment Share on other sites More sharing options...
Finch Posted July 25, 2012 Report Share Posted July 25, 2012 http://www.farmandsandtoys.com/partdetail.asp?partid=75 45$ Quote Link to comment Share on other sites More sharing options...
gotta_goatsfast Posted July 25, 2012 Report Share Posted July 25, 2012 Rid yourself of that stupid boost bottle and tune the carbs. In fact, just do a tune up in general. While its possible he might just be a better rider, it could be mechanical such as slipping clutch, air leak, incorrect jetting, fouled plugs, ect.... Quote Link to comment Share on other sites More sharing options...
jimmymichael Posted July 25, 2012 Author Report Share Posted July 25, 2012 Rid yourself of that stupid boost bottle and tune the carbs. In fact, just do a tune up in general. While its possible he might just be a better rider, it could be mechanical such as slipping clutch, air leak, incorrect jetting, fouled plugs, ect.... i had a guy tell me to smash the boost with hammer lol Quote Link to comment Share on other sites More sharing options...
jimmymichael Posted July 25, 2012 Author Report Share Posted July 25, 2012 (edited) and its not that he is a better rider i can ride his and feel the difference and i had tuned it infact his didnt run and i tuned it also now it runs better than mine Edited July 25, 2012 by jimmymichael Quote Link to comment Share on other sites More sharing options...
jimmymichael Posted July 25, 2012 Author Report Share Posted July 25, 2012 ive had mine since feb. and he just got his last week ill take that bottle off and advance timeing and see what happends thanks for ur time and help Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 25, 2012 Report Share Posted July 25, 2012 Other than double checking the sprocket counts and jetting, air box lid or not, etc., I wouldn't believe there would be a noticable difference from pipe brands, I notice mine looses a ton of bottom end when the pipes need packed. Quote Link to comment Share on other sites More sharing options...
jimmymichael Posted July 25, 2012 Author Report Share Posted July 25, 2012 (edited) Other than double checking the sprocket counts and jetting, air box lid or not, etc., I wouldn't believe there would be a noticable difference from pipe brands, I notice mine looses a ton of bottom end when the pipes need packed. i counted sprocket and tire size tonight and they are booth 14/41 and 20 inch tires and his is all stock jetting and mine is 30 pilot and 330 main i think id have to double check the main also his has no packing in and my packing is good and his has fatory air box and mine has k@n Edited July 25, 2012 by jimmymichael Quote Link to comment Share on other sites More sharing options...
Finch Posted July 25, 2012 Report Share Posted July 25, 2012 big pilot my guess is tuning Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 25, 2012 Report Share Posted July 25, 2012 i'm no expert, and don't know your elevation,maybe someone else will chime in here,but I think you might be dumping to much fuel, search jetting on here. Quote Link to comment Share on other sites More sharing options...
jimmymichael Posted July 25, 2012 Author Report Share Posted July 25, 2012 (edited) you are right 330/30 is pretty big for just fmf pipes. now if he has pods and maybe reeds those numbers would be better. it has boyesen reeds in it also k@n pods but i will for shure try different jets and also i live on Iowa Missouri bourder if that helps with elevation any ?? Edited July 25, 2012 by jimmymichael Quote Link to comment Share on other sites More sharing options...
