hoppedupandcutdown Posted July 26, 2012 Report Share Posted July 26, 2012 The choke on a Banshee ADDS fuel, so when it's out it's making up for an air leak. When it revs up on it's own -that lean- to much air...you have an air leak. Keep running it and you will have a hole in a piston. Quote Link to comment Share on other sites More sharing options...
Tommilicious Posted July 26, 2012 Report Share Posted July 26, 2012 Take the carbs off and tear them apart. Clean everything inside and outside of them. Get some carb/choke cleaner. Make sure you take out the main jet and clean it through. Make sure everything connected to the carbs is secure and not torn. Clean your airfilter under your seat really good. You can spray some carb cleaner spray on the boots and rubber connected to the carbs when you have it running. Check for your leaks this way.If you see it bubbling/spraying when moist you'll find your leak if it's in the rubber.... Put some new BR8ES or B8ES spark plugs in it. DO the simple/cheap things first to trouble shoot. I would also highly recommend putting new fresh gas in it. 93 octane with a 32:1 mix of good 2 stroke oil. Good luck Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted July 26, 2012 Report Share Posted July 26, 2012 Your going to regret continuing to run it, if you dont do a leakdown Quote Link to comment Share on other sites More sharing options...
Crbanshee1279 Posted July 27, 2012 Author Report Share Posted July 27, 2012 UPDATE: well turns out I dont know $@"t about carbs or banshees like I said this is my first time getting one going the idle screw was way out of wack had my little bro the banshee pro come look at it 5 min later runs great and kicks over 1 or 2 kicks thanks for all the help and suggestions u guys are very knowledgeable also keep up the good work Quote Link to comment Share on other sites More sharing options...
