Banshee SE Posted July 24, 2012 Report Share Posted July 24, 2012 I had a leak for the clutch cover so I change the gasket but the the FU#$%$# leak is here still. No sign of crack or anything like that. Could I use silicone with the gasket? any advice?? Thanks!! Quote Link to comment Share on other sites More sharing options...
Colby Posted July 24, 2012 Report Share Posted July 24, 2012 I had a leak for the clutch cover so I change the gasket but the the FU#$%$# leak is here still. No sign of crack or anything like that. Could I use silicone with the gasket? any advice?? Thanks!! i had a leaky clutch cover once.. put on a new gasket with some Ultra Black silicone.. fixed the problems.. make sure you clean the gasket surface area before putting on the cilicone though Quote Link to comment Share on other sites More sharing options...
Banshee SE Posted July 25, 2012 Author Report Share Posted July 25, 2012 i had a leaky clutch cover once.. put on a new gasket with some Ultra Black silicone.. fixed the problems.. make sure you clean the gasket surface area before putting on the cilicone though that's exactly I'm gonna do. I already bought the silicone, Thanks !! Quote Link to comment Share on other sites More sharing options...
