yanickfc Posted July 24, 2012 Report Share Posted July 24, 2012 Hey guy, My 2005 banshee does't start anymore!!!! :-( We cleaned the carb pretty well and buy 2 carb rebuild kit, they guy who installed carb is a mechanic so I'll asume it's installed well. He tested and gas goes in the carb I removed a spark plug and check if I have fire, yes I have a spark when kick starting when I've tried to pull start, it would burn some gas but it's not starting When I kick start, plug don't seem to get any gas I did a compression test, 80 and 100 psi My friend told me that reed valve seemed to be ok.. what do you think, could that low compression be the probleme or should it start anyway? Oh and no more tors, brain unplug Quote Link to comment Share on other sites More sharing options...
TheBigShabowski Posted July 24, 2012 Report Share Posted July 24, 2012 Compression seems really low. Prob time for a new top end Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted July 24, 2012 Report Share Posted July 24, 2012 Thats super low compression, sounds like its time for a rebuild. Make sure to do a leak down when your done Quote Link to comment Share on other sites More sharing options...
db25 Posted July 24, 2012 Report Share Posted July 24, 2012 Low compression for sure, sounds like it is time for a new top end Quote Link to comment Share on other sites More sharing options...
db25 Posted July 24, 2012 Report Share Posted July 24, 2012 Should be around 125 psi Quote Link to comment Share on other sites More sharing options...
yanickfc Posted July 24, 2012 Author Report Share Posted July 24, 2012 Yeah I know that compression is low and will need to do some job on top end but the question is Should the bike start with 80 and 100 psi or I am hunting for another problem? Quote Link to comment Share on other sites More sharing options...
bebetekbanshee358 Posted July 24, 2012 Report Share Posted July 24, 2012 Try push starting or a shot of starting fluid... Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted July 24, 2012 Report Share Posted July 24, 2012 With that low of compression, starting is very hard, if not impossible. As far as other problems being present, who knows, until you replace the top end. Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted July 24, 2012 Report Share Posted July 24, 2012 Try push starting or a shot of starting fluid... Do NOT use starting fluid. These take mixed gas, starting fluid isn't good lubrication. Pull starting should get it to pop up. Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted July 24, 2012 Report Share Posted July 24, 2012 Do NOT use starting fluid. These take mixed gas, starting fluid isn't good lubrication. Pull starting should get it to pop up. i think he means spray the air filters. that wont hurt anything Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 25, 2012 Report Share Posted July 25, 2012 pour a half a cap of oil in each cylinder thru the spark plug holes, that will tempoarily seal the rings so it will kick start. can also do a "wet" compression test that way. Quote Link to comment Share on other sites More sharing options...
yanickfc Posted July 25, 2012 Author Report Share Posted July 25, 2012 Do NOT use starting fluid. These take mixed gas, starting fluid isn't good lubrication. Pull starting should get it to pop up. you are right, he looks like it want to start when push start, there is a little smoke going thru exhaust I could try the trick with the oil in the cylinder, thanks for the help guys!! Quote Link to comment Share on other sites More sharing options...
