50 psi compression bike still running !
Could be a bad gauge.. Im not saying that your top end isnt toast but you could be getting a lower reading then what it actually is! I had bought a brand new gauge a couple of months ago that read about 35psi lower then what it really was!! Also when using a compression gauge you must use a tip that is as long as the spark plug to achieve the most accurate kicking reading!! If the tips are shorter the readings will also be lower by a few psi!!
