knobby668 Posted July 18, 2012 Report Share Posted July 18, 2012 I have mild ported engine I am rebuilding and would like to know what crankshaft you guys recommend. OEM or Hot Rods? Bike is used for trails and I want it as reliable as possible. Thanks. Quote Link to comment Share on other sites More sharing options...
ClayAiken Posted July 18, 2012 Report Share Posted July 18, 2012 Cant go wrong with either. Personally hotrods. Quote Link to comment Share on other sites More sharing options...
Coupelx Posted July 18, 2012 Report Share Posted July 18, 2012 I and many others run OEM cranks. Cheaper, just as strong if not stronger ,easy to find. I payed like 150 for the last one I bought and it was already welded up. Just had to put some bearings on the ends. Quote Link to comment Share on other sites More sharing options...
Tedder Posted July 18, 2012 Report Share Posted July 18, 2012 For a stock stroke setup I'd prefer an OEM crank but new they're outragous $$$ and about impossible to find with no hours these days so I go with Hot Rods (2nd choice). Quote Link to comment Share on other sites More sharing options...
knobby668 Posted July 18, 2012 Author Report Share Posted July 18, 2012 Thanks, I will order a Yamaha crank from from Parts Shark. About $400 shipped. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 18, 2012 Report Share Posted July 18, 2012 Thanks, I will order a Yamaha crank from from Parts Shark. About $400 shipped. I got mine here for 75 shipped Quote Link to comment Share on other sites More sharing options...
Dunes98 Posted July 18, 2012 Report Share Posted July 18, 2012 I have one that only has 20 or so hours on it. Already welded and has tz bearings. Louie from twister is the one that did the work. Befor he sent it back he checked it all out and said it was still in great shape and ready to use. I would sell it for $150.00 Let me know. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted July 18, 2012 Report Share Posted July 18, 2012 Why spend 400 on a stock stroke crank when you can buy a hotrods 4mill crank for 350 and then if you want to build your bike firther down the road you already have the crank for it? Quote Link to comment Share on other sites More sharing options...
knobby668 Posted July 18, 2012 Author Report Share Posted July 18, 2012 I am building it for a friend that does not ride very well and he will not be changing anything later. It already has a trail port with T5 pipes, more than enough power for him. Just want to give him something that will last a long time. Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted July 18, 2012 Report Share Posted July 18, 2012 4 mil welded hotrods , drops right in and more reliable than stock. jmo Quote Link to comment Share on other sites More sharing options...
knobby668 Posted July 19, 2012 Author Report Share Posted July 19, 2012 4 mil welded hotrods , drops right in and more reliable than stock. jmo More reliable because of the decreased rod angle of the longer rod or that the hotrods is stronger? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted July 19, 2012 Report Share Posted July 19, 2012 4mill crank might help him ride a little better with the increased low and mid range due to the extra stroke. For most guys running a 4 mill we give up the extra low end for some more top end but if you kept it a mild port then it would make for a better low, and midrange. I would put it together with a 4mill long rod crank, wiseco 795 series pistons and a cut head. If you space the cylinders off the case then your raising the port hights 2mm wich will in general shift the power to the top end. Quote Link to comment Share on other sites More sharing options...
