421 cub jetting help!
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
Wow you guys are all running a lot bigger mains than I am. I have a 421 cub clean up port with shearer inframes and 34pj carbs and I am running a 50 pilot and a 148 main and have been runnning that setup for 2 years. Make sure you are turning your choke knobs all the way in and adjust the idle with your cables other wise you are going to have a hard time getting those pj's set right.
  • 2 weeks later...
ok got the bike together and did a leak test, lost 1psi in 6min. is that acceptable? anyhow, now my left side pipe is getting hot way b4 the right side. carbs are synced pullin 4 even on the syncronizer. i got spark on both sides, what else kud it be fellas??
Finally g the bike out riding today and she's running good. A 165main jet is still very rich, so il b dropping down to a 162 or 160 main. Maybe mess with the needle a bit and see what happens during the week. Il post up vids next week with the go pro cam. Shud have some good footage
Fired mine up this weekend and so far seems a bit rich.
Set up:
421 cub stock
22cc domes from FAST
HR crank
Timing +6
VF3
35mm pwks with CEL needles 162m 55p 1.5 out
Shearer SB in frames
Nology coil and wires
