421 cub jetting help!
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
I'm goin to be running a 421cub with a clean up port with 34mm keihin pj,shearer sb inframes,vf3,+4timing,sea level,pump gas. About where should I begin jetting??
Im running the same setup on 100ll using 55 pilots CEG needle mid clip 160 mains at sea level. It runs like a raped hostage.
Edited by 252wheelieking
i run 160 mains, CEL needle middle clip and 52 pilots with 35 pwks
I havent started my motor yet but im guessing I will be close im on a 162m,55p,cel needle middle clip,2 out screw, at sea level
What's your setup? Mine is a 421 cub with sb shearer inframes, 35 pwk's, vf2's. I really haven't ridden mine enough for the rings to seat but my jetting feels close. Im at 300' asl.
Ok I go bike together, I'm goin to do a leak down test on Friday. I started her up already she sounds healthy but haven't rode it at all. I got a 52 pilot and 165main with air/fuel out 2.5 turns and it wont idle high enuff. Shud I jump to a 55pilot? I tried a 50 already but nothin. All help is appreciated
havent pulled the choke yet. so far i even went as far as all the way in on the air/fuel screw and half a turn out but still wudnt idle. i had it idling at one point but it was too low n wen id try to turn it up it wud die out. right now its at 3 turns out and wont idle.
idle speed on pjs is adjusted by turning the choke knobs, im not sure everybody knows that if you do sorry for the highjack. The airscrews are for idle "quality" and off idle performance. If you want to raise idle speed turn the choke knobs counter clockwise
I am on the Oregon coast and I have a 421 with a 152 main, needle in the middle clip not sure on the air screw. 35pwk. I have 19cc domes, VF3 reeds with suffers. My cylinders are ported by HJR with a aggressive port job. I have cpi in frames and I am running +7 timing and c12 fuel. My bike has been tuned on a dyno and runs really good. Cam at Redline did the work.
