help with rich banshee
ernesto
hi i have a 2000 banshee with , tors eliminator , tommey 6 pipes , k n air filter , everything else stock .
main jet 280
pilot 25
screw 1.5 turns
i live in panama * sea level , the bike is running extreme rich , should i use 200 or 260 main jet ????
thanks
Edited by ernesto
First thing is to find out where the bike is running rich at!! I dont think your main will be to far off from the 280s you have in!! Id say your needle position is what you have to work on!! A plug chop will get you dialed in for the main size!!
Thanks for the help , so I need to move the clip on the main needle I have it in the 3rd pos , stock
Should I move it 1 lower or 1 upper???
Thanks
hi i just try moving clip 1 up and it feels better now but still rich , but thanks for the help , im using vitto rebuild kit for banshee , i take a picture of the main needle i use to have and the one im using this moment
the gold one ( short one) stock
the silver one (long one) vittos kit , actual using
why is longer ???
should i use the gold one ????
Ernesto the stock needles are fine with your mods. It looks like the vitos needles are a bit thinner at the low throttle taper which would make it very rich. I would use the stock needles. There is no reason the vitos needles need to be that long.
Thanks men i will change them back to stock ones and try , 3 # clip as stock ?
