Shearer or sniper pipes
Someone needs to tell Brad Painter (Banshee 332). Today I looked up at the BBDR points for 2012, Brad has won the first four races (431 to 525 two-stoke class), racing against nothing but Shearer piped bikes. And yes, that is the very same engine that was in the Passion/Shearer challenge.
Congrat's Brad
http://search.yahoo.com/r/_ylt=A0oG7lg9pQhQHGsAk0ZXNyoA;_ylu=X3oDMTE0amJhaGpnBHNlYwNzcgRwb3MDMQRjb2xvA2FjMgR2dGlkA01TWTAxMl83NQ--/SIG=11h4s0qar/EXP=1342772669/**http%3a//www.bbdrdirtdrags.com/
Thanks man, I stuck a ring the forth race I still some how got first, the 5th race is not posted yet, I ended up get third. I tired a 4 inch shorter swing arm to try to get out of the hole faster and it end up hurting me my e.t's where 3 thenths higher and my mph was 4-6 mph slower, I was fighting the bike over 1/2 track to go straight.
In the 386 to 430 class, did a Sniper piped bike win a race?
I have a set of IF FMFs I'd sale to only a experienced rider. These pipes make about 13-14 hp more than any pipe on the market, tested on a professional butt dyno. My 4mm Serval Ran .02s with them, the sand literally will turn into glass from the velocity and heat that your paddles will make when spinning. Faces have completely melted off from running these pipes without a full face NASA approved helmet on. There is a good possibility you might be timed warped into the future or past from the incredible speeds you will see running these custom pipes. Custom grips with straps holding you to the bars are required and I might be willing to let mine go with the sale but only to a very experienced rider. My Banshee runs 180 KPH in 1st gear with the pipes. So if you want "The Best" pipe on the market for any application, then PM me your references so I can verify your experience and will decide who is deserving of the monsters. I also am not responsible for any deaths or disappearances from the use of the pipes once they are out of my possession.
THAT is some funny shit!
Edited by BSPolice
if someone within 250 miles of 73942 has a dyno and a stock cylinder motor and 421 cub, i will buy the snipers and let you use them to test as long as i can be there watching/videtaping
i am 424 miles and have a Decent stock cylinder motor.
Yeh he does pretty good, his set up is far from perfect but it works pretty decent.
Heads up, index, or bracket? In frame or out? What cc is the bike? What is the best time it has ran? This question is for both bikes that are running the sniper that were mentioned.
I think this thread is ready for deletion
Do not delete my thread. I had a legit question. Did not know shit about the sniper pipes. That's why i asked. There are so many know it alls. Put no solid proof. Looks Shearers will stay on. They sure are a good pipe.
Just remember, the world is flat....
