spurdy Posted July 12, 2012 Report Share Posted July 12, 2012 ASV shorties and 6 HD springs here with a Terry Cable. No issues with the pull. Even my 12 year old rides it with only a little complaining. SP Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted July 12, 2012 Report Share Posted July 12, 2012 ASV regular length here i believe. I run 3HD and i would not want it any harder. I like as light a pull as possible. Tried the MSR Raptor lever i think it's called, it broke where you adjust the ease of pull after a short while. You can sometimes get cheap refurb ASV's on ebay. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 12, 2012 Report Share Posted July 12, 2012 You guys that have a hard pull with a shorty lever are either little girls or something is not adjusted right. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted July 12, 2012 Report Share Posted July 12, 2012 I'm running a No Limit HD clutch with 6 HD springs, motion pro cable, and a lockout with the stock lever none the less and have 0 problems. Fuck all that bearing bullshit!!! Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted July 12, 2012 Report Share Posted July 12, 2012 ASV Quote Link to comment Share on other sites More sharing options...
blubyyou Posted July 12, 2012 Author Report Share Posted July 12, 2012 Well I think I'm gonna try the ASV shorties .....they look good and seem to have good reviews. Worst case I hate then and put them up for sale on here....take a loss and buy msr lol. Changing the subject...I run 3 hd springs now with a tusk clutch along with a new oem cable. I seem to get a little slip on pavement with my 4mil. Bike is fresh less than 15 hours on it....wonder if 6 hd springs would cure this? I ride trails mostly ....and it seems it does it the most on pavement. I did get it slipping when i was cutting a few doughnuts a while back in the dirt. I'm thinking I need to buy a better clutch like FAST sells. What's your opinions? Quote Link to comment Share on other sites More sharing options...
Nightmare Posted July 12, 2012 Report Share Posted July 12, 2012 On pavement you cant expect much from tusk. Especially with a 4mil. If you got the cash go for the fast unit or call Andy at No Limit. Quote Link to comment Share on other sites More sharing options...
blubyyou Posted July 12, 2012 Author Report Share Posted July 12, 2012 By the way it seems more noticeable 4-6 on pavement....maybe I'm just imagining things and the bike just goes through the gears this damn fast. I will say it definitely hauls ass with the HJR dune/play port 4mil. Quote Link to comment Share on other sites More sharing options...
blubyyou Posted July 12, 2012 Author Report Share Posted July 12, 2012 Where does the spending on the banshee ever stop? Here we go again...." Jeff, send me a billet basket along with you clutch" should I go with 6 hd springs or is 3 sufficient? I didn't know if running 6 would help out the tusk I have in it now as far as slipping goes? Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 14, 2012 Report Share Posted July 14, 2012 Where does the spending on the banshee ever stop? Here we go again...." Jeff, send me a billet basket along with you clutch" should I go with 6 hd springs or is 3 sufficient? I didn't know if running 6 would help out the tusk I have in it now as far as slipping goes? I was running 3 hds on my hjr dune port 4 mil and was slipping off the line in the sand and causing miss shifts between 3rd and 4th (running a dd lockup and override). Switch to 6 hds and the slippong and miss shifts seems better. I still don't see the issue pulling the lever with the ASV shorties. I do travel for a living so I guess I have got a pretty good grip ! Then again, I am predomonantly right handed and there is no need here to use both hands often . SP Quote Link to comment Share on other sites More sharing options...
blubyyou Posted July 14, 2012 Author Report Share Posted July 14, 2012 Thanks spurdy. I think I'm going to hit Jeff up @ FAST and get the billet basket, new clutch, throw in 6 hd springs along with the ASV shorties. This should fix my problem for sure. Just went out and now I have play in my durablue axle.....the sprocket & rotor move a little front and back before the axle turns. Damn where does it end lol. Guess i will just shell out the $750 or so for the Lonestar axle, hubs, rotor hub, and sprocket hub....problem solved. I don't know which one is a bigger money pit.....banshee's, boats, or sports cars! Always something .... Quote Link to comment Share on other sites More sharing options...
