NA5TY Posted July 10, 2012 Report Share Posted July 10, 2012 I just put 34mm carbs on my banshee, I havnt checked the jet size or anything yet but.. when I open it up it does great threw the first 3 gears but 4th 5th and 6th when the powerband should kick in it kinda bogs and wont open all the way up any idea while or suggestions? Quote Link to comment Share on other sites More sharing options...
NA5TY Posted July 10, 2012 Author Report Share Posted July 10, 2012 they are sync'd at idle at 3,000 and i set both on 5,000 Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted July 10, 2012 Report Share Posted July 10, 2012 check jet size and find out what needles you have in them.... Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted July 10, 2012 Report Share Posted July 10, 2012 i prolly would have checked what jets it has in em before fitting them. pull them off and see what jets are in there, and post up your mods and elevation. Quote Link to comment Share on other sites More sharing options...
bansheeboi Posted July 10, 2012 Report Share Posted July 10, 2012 I've got some jets laying around if u need them Quote Link to comment Share on other sites More sharing options...
NA5TY Posted July 10, 2012 Author Report Share Posted July 10, 2012 kk thanks for so many response's yea i should have checked b4 puttin on but I got in a hurry like something dumb.. Im located in West Virginia unsure what elevation that would be.. im running T5 Exhaust V force 3 reeds Cool Head with 20cc domes 34mm carbs pretty simple set up will check jet size and needle valve position tomorrow after work.. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted July 10, 2012 Report Share Posted July 10, 2012 what 34mm carbs are they, mikunis, keihin , round or flat side ? Quote Link to comment Share on other sites More sharing options...
NA5TY Posted July 10, 2012 Author Report Share Posted July 10, 2012 what 34mm carbs are they, mikunis, keihin , round or flat side ? keihin.... flat side needle it dont look like the needle valve can be adjusted main jets size is a AB152 Piolet 58 Quote Link to comment Share on other sites More sharing options...
NA5TY Posted July 11, 2012 Author Report Share Posted July 11, 2012 any idea's ? Quote Link to comment Share on other sites More sharing options...
hp2000 Posted July 11, 2012 Report Share Posted July 11, 2012 Main seems low for a pj carb try a 158 if you have some... Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 11, 2012 Report Share Posted July 11, 2012 Needle is easy. Pull the cap. Finger fuck the spring out of the slide and compress it against the cap. Push the cable down and out. Use a phillips driver or nut driver to push down and turn the spring loaded lock 90*. The needle is now free As for jetting, never put any carbs on your bike with out researching and knowing what is inside them jet wise. You could of blown that thing up and made an Uh Oh I think it's toast thread. Those pj carbs are pretty easy. Mark the choke knobs so you can turn them out in sync to set the idle. Should be out about 7-7 1/2 turns. As for jets a 55 pilot, needle in the middle, and a 155 main should be enough to get you started on your mods. You will probably lean it up a touch past that. I think in the end you might be about 48, second clip from top, and a 150/152. Give that a try and report back with results Quote Link to comment Share on other sites More sharing options...
NA5TY Posted July 22, 2012 Author Report Share Posted July 22, 2012 Needle is easy. Pull the cap. Finger fuck the spring out of the slide and compress it against the cap. Push the cable down and out. Use a phillips driver or nut driver to push down and turn the spring loaded lock 90*. The needle is now free As for jetting, never put any carbs on your bike with out researching and knowing what is inside them jet wise. You could of blown that thing up and made an Uh Oh I think it's toast thread. Those pj carbs are pretty easy. Mark the choke knobs so you can turn them out in sync to set the idle. Should be out about 7-7 1/2 turns. As for jets a 55 pilot, needle in the middle, and a 155 main should be enough to get you started on your mods. You will probably lean it up a touch past that. I think in the end you might be about 48, second clip from top, and a 150/152. Give that a try and report back with results ok went with ur advice on the jets , it is now opening up pretty smooth an is almost in sync but i think my left side is off still just a nudge what would make it sound like a pop can ting around the header pipe on the left side ?? Quote Link to comment Share on other sites More sharing options...
