esseclipse Posted July 6, 2012 Report Share Posted July 6, 2012 I have a 2000 Banshee that is mostly OEM, I took apart the top end and measured it, it is 64.50. I brought it to a local shop to check out, he recommended I just buy a new 64.50 top end kit and he would hone it. Top end kits are pretty expensive and I want to do the rebuild right, should I take his advice or should should I go up a size and get it bored to match the new pistons. If so, which size would you have it bored to 64.75 or 65.00? Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted July 6, 2012 Report Share Posted July 6, 2012 if you trust the guy and he says it needs that size then go with that. if you dont trust him take it somewhere else... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted July 6, 2012 Report Share Posted July 6, 2012 There is 6 measurements you have to take. If your to far over, out of round, tapered or any gouge you should bore it. Why do you think you need a top end? And how reputable is thus local shop? Quote Link to comment Share on other sites More sharing options...
esseclipse Posted July 6, 2012 Author Report Share Posted July 6, 2012 The quad was beat and not maintained at all, I have completely rebuilt it and I wanted to start with a new top end, he is reputable and really the only local place for me to get it bored and honed. I would just prefer to have a fresh bore rather than just honing it and wanted some advice on what size I should go to. Quote Link to comment Share on other sites More sharing options...
toytech Posted July 8, 2012 Report Share Posted July 8, 2012 if it's good then dont bore it. why waist a bore? Quote Link to comment Share on other sites More sharing options...
421alkybanshee Posted August 4, 2012 Report Share Posted August 4, 2012 send to a site sponsor. there are many reputable shops on this site that will help you out correctly Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted August 8, 2012 Report Share Posted August 8, 2012 If it truly just needs a hone job, then why do you need to buy pistons? Are they broke or cracked? If it is just being honed and your pistons are OK, I would just buy some rings and the required gaskets and put it back together. Quote Link to comment Share on other sites More sharing options...
teamziehm race Posted August 23, 2012 Report Share Posted August 23, 2012 take it to a machine shop prob solved bud Quote Link to comment Share on other sites More sharing options...
lms1977 Posted August 23, 2012 Report Share Posted August 23, 2012 It would to bore it unless he checked it with a bore gauge. If your that far you might as well do it right. Quote Link to comment Share on other sites More sharing options...
