I have a 1996 banshee I would like to sell i would like to get some around 3800. my numbers 816-273-2447 text me anytime,zach. here's some of the mods i know im for getting some of them, here's some pics I really need the money so make a reasonable offer and i will probaly take it! http://s1157.photobucket.com/albums/p592/gillette96/
68mm bore 54mm stroke cub, the cylinders have been recoated and has a new set of wossener pistons not even 10 gallons ran threw it yet.
cylinders have been ported
hot rod crank(stock stroke)
cool head with 22cc domes
boyesen reeds
32mm carbs
k&n air filters
cpi pipes
adv timing
billet clutch basket,r6 clutchs with a lock out and a see threw lock out clutch case
1-5 override transmission
roughend cases
new water pump seal
chrome a arms with new bushing and ball joints
chrome +10 swing arm with round style carrier
chrome axel
chrome kicker
chrome tie rods
chrome pegs
chrome break pedal
newer break pads
all new steal braided break lines
protaper handle bars
asv levers
billet gas cap
billet spindles
billet shifter
billet 3 peice stator cover
billet dip stick
pro lite front bumber
15/44 gear
all new tires and wheels also have a set of drag tires to go with it
custom air brushed front fenders
the only thing it needs is the rear shock charged and i think yamaha does it for like 30 buck right now i have a strut for the shock,Im guessing it makes some where between 90-100 horse with the drag tires with will flip over in every gear(if it hooks) it would run a high 6 in the 8th mile when it was a 64mm bore and now its a 68mm bore so im guessing it would run a 6.80 or so in a eigth
boyesen reeds
32mm carbs
k&n air filters
cpi pipes
adv timing
roughend cases
new water pump seal
chrome axel
chrome kicker
chrome tie rods
chrome pegs
chrome break pedal
newer break pads
asv levers
billet gas cap
billet spindles
billet shifter
billet dip stick
15/44 gear
sorry for got to put location,st.joseph MO willing to travle a lil ways to meet.
Sounds and looks like you got alot of nice, clean, and expensive aftermarket parts on it. Might be better off parting this one out. If you have time.... Good luck with sale.
I'm interested in the protaper handle bars, asv levers, and wheels/tires if you decide to part out.
Edited by Tommilicious
  • 4 months later...
