Banshee dies after WOT
I just moved from Oregon to Northern New Mexico. Went from About 1000ft to 6000ft and now after i run WOT it starts missing.. It has bogged out and died a couple times now! I let it sit and it would start back up..but still misses .. I let it sit for a while then go putt around with the kids and runs fine at low rpm's.. I have 310 mains with stock pilot ,needle on 3rd clip.. airscrew 1 1/2 turns out.. It has no air box lid with a pro flow adaptor pro design foam filter and toomey T-5's.. Stock internals.. emergency brake and tors removed..Kinda seems like it runs outta gas.. Not sure! banghead Gonna ride it and turn the gas off atfer it dies and pull the bowls to see if they have fuel tomorrow.. any other suggestions would be great! Thanks!
Edited by Somedumbguy
very simple.. with the elevation change you are now running it too lean up top.. is it popping?? you are lucky you havnt melted a piston yet.. start with putting a bigger main jet in the carbs
Assbackwards.
Going up in elevation, air is less dense, and requires less fuel.
welcome to nm....as stated you are going to have to rejet,you are running rich plugs are probably getting all fouled out and it is cutting off.how are you adjusting to the higher elevation?it takes a while for sure
I have adjusted fine but the shee wasn't too happy! Yesterday was the first time riding it! Thanks for the reply's.. I will drop my jets down and let you guys know how it goes.. Thanks again! :cheers:
I droped it from a 310 to a 280 and it seems to like that. I also found the orange wire that runs to coil was touching against my exhaust and was melted a tade with exsposed wire showing.. {Tried to reroute wires to hide them... banghead } Fixed that and now she is screaming again :headbang:
