zach15 Posted July 4, 2012 Report Posted July 4, 2012 I have a 1996 banshee I would like to sell i would like to get some around 3800. my numbers 816-273-2447 text me anytime,zach. here's some of the mods i know im for getting some of them,i couldn't upload pics but there are pics on craigslist so here's the url http://stjoseph.craigslist.org/mcy/3117487495.html 68mm bore 54mm stroke cub, the cylinders have been recoated and has a new set of wossener pistons not even 10 gallons ran threw it yet. cylinders have been ported hot rod crank(stock stroke) cool head with 22cc domes boyesen reeds 32mm carbs k&n air filters cpi pipes adv timing billet clutch basket,r6 clutchs with a lock out and a see threw lock out clutch case 1-5 override transmission roughend cases new water pump seal chrome a arms with new bushing and ball joints chrome +10 swing arm with round style carrier chrome axel chrome kicker chrome tie rods chrome pegs chrome break pedal newer break pads all new steal braided break lines protaper handle bars asv levers billet gas cap billet spindles billet shifter billet 3 peice stator cover billet dip stick pro lite front bumber 15/44 gear all new tires and wheels also have a set of drag tires to go with it custom air brushed front fenders the only thing it needs is the rear shock charged and i think yamaha does it for like 30 buck right now i have a strut for the shock,Im guessing it makes some where between 90-100 horse with the drag tires with will flip over in every gear(if it hooks) it would run a high 6 in the 8th mile when it was a 64mm bore and now its a 68mm bore so im guessing it would run a 6.80 or so in a eigth Quote
Tommilicious Posted July 4, 2012 Report Posted July 4, 2012 Pull that sweet banshee outta the garage and get some full pics up! Quote
zach15 Posted July 4, 2012 Author Report Posted July 4, 2012 Pull that sweet banshee outta the garage and get some full pics up! it won't let me upload them on here so im using CL to get them on here http://stjoseph.craigslist.org/mcy/3117582854.html if it would let me uplaod them straight on here i would put more but it sucks to do threw CL Quote
zach15 Posted July 4, 2012 Author Report Posted July 4, 2012 Here's a couple more pics http://s1157.photobucket.com/albums/p592/gillette96/ the paint has a couple small cracks in the back and the front has a couple small cracks. Really need to sell!! if you are enterested Pm me Quote
