what size domes
You sure you don't have a 4mil? Every builder has their own way of marking things.......but I believe that the 18+2 means they are 18cc domes and set up for an extra 2mm of stroke. So Im curious if your crank is a 4mil crank. Either way 18cc domes are tiny and usually mean that you should be running race fuels.......depending on elevation of course. But unless your up near the top of k2 you may need to check your compression before running that thing on pump fuel....
