banshee dogbone has play
banshee#44
  • 1 month later...
Hey guys just wondering id this is normal because i looked at a diagram and everything is there, just wondering if your banshees dogbone has left to right play where the it
connects to the frame.
Are you talking about the transfer bar, that joins the frame behind the motor, not the connecting rod that connects to the swing arm? If so there are two bushings that drive into the end that connects to the frame that can be replaced along with the bolts and such.
