Pilot Jetting
Hey all. I've been trawling through everybody's jetting combos and I'm wondering if I'll need to go to richer pilots. I've done a top end rebuild, Pro-Lites, Chariot head 21cc domes, T6's, VF3's, Pro-Flow foam filter with lid off, +4 timing. Elevation is 1000' and air temp around 70°F. I'm going to 320 mains, I used to run a vented lid. But do I need to go to 27.5 pilots? Also is stock 25? I see some people with similar mods still running stock pilots.
A bit of an update, I'm thinking of running Pro-Design intake manifolds for V Force reed cages (No boost bottle). I'm assuming this will increase the low speed air velocity and give a bit more bottom end. Will this require the 27.5's rather than stock manifolds? Or should I just get a set of Moose Racing polyurethane ones? I do a lot of trail riding so I want to smoothen the transition from low to high a little bit.
