02bansheebrah Posted June 30, 2012 Report Share Posted June 30, 2012 ok so i have noticed latly fuel has been coming out of my vents on my carbs is this normal or is it a needle and seat problem? thanks Quote Link to comment Share on other sites More sharing options...
Finch Posted June 30, 2012 Report Share Posted June 30, 2012 needle and seat or stuck float. id take em apart and clean them real good and see if that does it Quote Link to comment Share on other sites More sharing options...
thomas h. Posted July 1, 2012 Report Share Posted July 1, 2012 Remove the brass seat and use gritty tooth paste and q-tip to clean the seat. I bought new oem needles and seats and they leaked from sitting then used this trick ans it worked good ( also on several other banshees too) Quote Link to comment Share on other sites More sharing options...
02bansheebrah Posted July 1, 2012 Author Report Share Posted July 1, 2012 Remove the brass seat and use gritty tooth paste and q-tip to clean the seat. I bought new oem needles and seats and they leaked from sitting then used this trick ans it worked good ( also on several other banshees too) ill try that if they stil lleak after i clean them! Quote Link to comment Share on other sites More sharing options...
