jetting help
fzank
Hi Everybody,
I'm from Belgium and I've just finished to built up my banshee.
So now I have some problems in choosing a correct jetting... so I know that you have a lot of same questions but I will hope some of you can help me.
Here is my set up :
- Stock engine
- boyesen reeds
- oko 30mm
- spacers of 5mm between cylinder and reed cage
- FMF SST
- Open air box with a foam filter
So can you give me the best jetting for this set up
THANKS VERY MUCH
I'm at 250 meter up the sea level and the t° is 20c°.
I don't find a good set up for my oko 30mm.
Somebody told me the reason of this is , maybe, the oko carbs who need a k&n air filter without air box.... what do you think about that?
He told me the oko are compatible 2 stroke and for stroke and they don't work with airbox???
Do you think normal that with my set up a jet pilot of 55 is to small?
Till yesterday when I start from the stop position in first gear I have a bir Boooooh with no power I have to clutch I make a big throtle to start normaly... and yesterday I put at air srew 1/4 turn and the problem go away so I have to put a bigger jet than 55 but It's so big...
Do you think my problem can come from a air entrance from the case of engine? How can I check this?
