JDP421 Posted June 28, 2012 Report Share Posted June 28, 2012 I have a 1987 banshee that I just had redone by k&t performance . And the bike will not start! I can get it to pull start after a few try's but that's it . Any advice on wat this could be? I can sit and kick it and it will not even show signs of starting . -thanks Quote Link to comment Share on other sites More sharing options...
toytech Posted June 29, 2012 Report Share Posted June 29, 2012 I have a 1987 banshee that I just had redone by k&t performance . And the bike will not start! I can get it to pull start after a few try's but that's it . Any advice on wat this could be? I can sit and kick it and it will not even show signs of starting . -thanks did you do a compression test? is it properly jetted for the mods you had done? does it have good spark while kicking it over? Quote Link to comment Share on other sites More sharing options...
Finch Posted June 29, 2012 Report Share Posted June 29, 2012 weak spark? Quote Link to comment Share on other sites More sharing options...
banshee760 Posted June 30, 2012 Report Share Posted June 30, 2012 Are you shure it's not flooded ?? Give us a lil more info on the build altitude , jetting, setup ? Quote Link to comment Share on other sites More sharing options...
JDP421 Posted June 30, 2012 Author Report Share Posted June 30, 2012 Sorry by the bad info. It's a drag ported 421 cub 35 mm carbs everything's been timed jetted all that good stuff and there is no spark . Quote Link to comment Share on other sites More sharing options...
JDP421 Posted June 30, 2012 Author Report Share Posted June 30, 2012 And I'm located in California valley and I think our altitude is like 117 feet above see level . But everythings been jetted properly Already . And It did run during or break in period for the motor and now there's no spark Quote Link to comment Share on other sites More sharing options...
toytech Posted July 1, 2012 Report Share Posted July 1, 2012 check the airgap on the pickup coil. and the coil and plug ends for resistance. Quote Link to comment Share on other sites More sharing options...
