fastcar01 Posted June 26, 2012 Report Share Posted June 26, 2012 Are all stators interchangeable except the square vs round plug? 87-94 used round and 95-07 used square? Eitrher way if I just switch the plugs can I use an old one in my 96? Thanks Quote Link to comment Share on other sites More sharing options...
FOXBANSHEE30 Posted June 27, 2012 Report Share Posted June 27, 2012 Are all stators interchangeable except the square vs round plug? 87-94 used round and 95-07 used square? Eitrher way if I just switch the plugs can I use an old one in my 96? Thanks Can't see how it could be a problem, didnt seem to change anything much after the older models. Wouldn't hurt to try if you have an old one and a soldering gun/iron... Quote Link to comment Share on other sites More sharing options...
Finch Posted June 27, 2012 Report Share Posted June 27, 2012 dont think it works that way but havnt ever heard of someone trying it, Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted June 27, 2012 Report Share Posted June 27, 2012 87-94 were round plug 95-96 were their own plug and 97-06 were the same. They push out the same power so you can splice wires and make it work but as for plugs those are the different years that they switched. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted June 27, 2012 Report Share Posted June 27, 2012 87-94 were round plug 95-96 were their own plug and 97-06 were the same. They push out the same power so you can splice wires and make it work but as for plugs those are the different years that they switched. This is the correct answer.. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 27, 2012 Report Share Posted June 27, 2012 87-94 were round plug 95-96 were their own plug and 97-06 were the same. They push out the same power so you can splice wires and make it work but as for plugs those are the different years that they switched. That is the CDI box NOT the stator!!!!!!! There are 2 stator plugs-87-94 round plug and 95 on square plug. That is the ONLY difference between the two. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted June 27, 2012 Report Share Posted June 27, 2012 Yes. Their are only 2 different style stator connectors. Round and square. Nothing changed but the plug . Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted June 27, 2012 Report Share Posted June 27, 2012 That is the CDI box NOT the stator!!!!!!! There are 2 stator plugs-87-94 round plug and 95 on square plug. That is the ONLY difference between the two. I stand corrected. I was pretty sure the whole harness was different with the CDI but I guess not. Thanks for correcting me. Quote Link to comment Share on other sites More sharing options...
