Need more Bite!
sprinklerman
If your bike sits high in the back that will suck with those tires. Get one of the $30 billet lowering blocks and get your grabbar about 5" lower and it will help a ton. With about that power and a +6 my old gas bike liked 21x12x8 9 or 10 paddle extremes. If you are lighter than 200 lbs go with a 10 extreme in either a 21 or 22. They are both real close to the same size but the 21" is lighter. If you meet up with us sometime I can come up with about every tire to try.
I'll take you up on that. When it slows down a bit with work (and cools off) we are planning a trip to LS. Also, my swingarm is level , to slightly below parallel.
I thought u said the bike sat up in back, I gotcha now you were saying swingarm was up in back. You probably cant go lower. With a plus 6 swinger a 10 paddle 21x12x8 is a great tire as well as 22" 9 and 10 paddle.
Yea. its pretty much parallel to the ground...but i had to loosen the shock quite a bit to get enough sag for it to get that way. Would i be better off setting the shock a little stiffer and then use one of those lowering blocks?
Are you on a track? If so eliminate the rear shock and strut it, Id also sprockets are a hell of alot cheaper then tires, I run 15-43 gearing with 14 paddle staggered extremes
No track,just dune style. Kind of rough actually. I put on a 15/40 setup on it , so we can try that this weekend. As far as the lowering block for the rear,,is there a benefit to stiffening my rear shock back up and running that block? Or is it ok to back the shock way off to get the swinger level? Which way promotes better hook out of the hole?
...is there a benefit to stiffening my rear shock back up and running that block? Or is it ok to back the shock way off to get the swinger level? Which way promotes better hook out of the hole?
IMHO, stiffer is better. the soft shock will soak up the weight transfer. I run a shaw at the dunes/river and adjust so I get ~1" of "squat" when I launch.
