NO 4th Gear....Rides Fine Until 4th HELP!
Banshee was riding fine until i switched into 4th gear. I thought the chain had popped off or the sprocket come off the motor. I can bypass 4th and go right into 5th and it rides fine in that gear. I do not know if I have clutch problems or trans gear problems. PLEASE HELP!!!!
definatly trans problems, i suggest stop riding and split the case
Yeah I'd stop riding to. Does it click into 4th?? I'm thinking you either sheared some teeth off or the dogs are completely wiped. Which both would be amazing and I would love to see pictures. It had to have made some sort of loud noise. Maybe the fork is completely grooved on one side not engaging the gears. You didn't hear anything at all??
