Big_Dave Posted June 18, 2012 Report Posted June 18, 2012 Im converting from alky back to gas. I havnt really messed with my banshee for about a year and a half. Im converting it to gas so i can trail ride it in a few weeks on a ride dedicated to my friend that passed away last saturday. I need to get get rid of the 39mm pwk's and CPI OOF silenced pipes for something a little more ridable. Its a stock cylinder 4mil 5mm longrod. I got it from Sheefreek about 2 years ago. It ran about 135lb of comprestion each cylinder. I was thinking about some 35's and a set of CPI small bore in frames. suggestions on where I could trade my stuff for what im looking for? I have ads in the swap and trade and wanted but no one really responded. Quote
Big_Dave Posted June 18, 2012 Author Report Posted June 18, 2012 If I could sell the top end off of this machine I would. Id like to keep the bottem end. its a 4 mil alky setup by patriot. not sure what size domes. Id like some help putting a 421 together. Help pleese? Quote
RC418 Posted June 18, 2012 Report Posted June 18, 2012 Would you trade the pipes for some T6's? Quote
Big_Dave Posted June 18, 2012 Author Report Posted June 18, 2012 Would you trade the pipes for some T6's? Id like to get CPI's, or Shearer's. Thanks for the offer but no. Quote
Starwriter Posted June 20, 2012 Report Posted June 20, 2012 (edited) That's a lot of swapping to get done and jetted in a couple weeks. I would say if you're going to have any chance of pulling it off, you should get lower compression domes from the people that made your head, back off the timing and buy some gas carbs and inframe pipes. Then sell your leftovers later. Of coarse, be sure to tell them it's a 4 mil long rod when you order the domes. Just reread your post. You only have 135 psi compression. You don't need different domes. Edited June 20, 2012 by Starwriter Quote
mike0chek Posted June 20, 2012 Report Posted June 20, 2012 my similar setup pulls real hard with 35mm carbs and inframe shearers Quote
