Serval 421 jetting w/ mikuni VM32's?
As title says - just put together a serval 421, need to jet. I'm using a pair of VM32's, mostly just because they're what I've got around. I know they might not be ideal - let's skip the bit where we talk about why PWK 28's would be better.
So, on to jetting - setup is: serval 421 w/ 24cc domes at 500ft, squish at .042", uni pod filters, stock timing, mixing Motul 800 at 32:1. Anyone got a ballpark on jetting?
Thanks!!
I dont mind those carbs. It seems like with the vm 34 carbs we ran about mainjets in about the 260/270 range. I would think the 32s would be a little smaller than that. All the VMs I have had needed the needle leaned out one or two clips from the middle. I would expect it to be in the low 200 range dor main but you might wanna start at 270 and only run it 50 or a hundred feet or so and keep checking it as you go down. 34mm mikuni flatslides I ran 250 mains.
with the 34tm radar speaks of with the 421 it doesnt. ive been trying to jet mine and i started at 350 and im at 280 now and its heaps better but not perfect i still need to drop a few main sizes. ive been scared to lean it but these carbs just dont need that much main. thats with the flat slides.
radar, what dumps where you using ? 389 q0 -q2's ?
Holy cow. Those must have wierd slides or needles. Thats kind of the problem with oddball carbs. Usually a small carb like that was designed for some small or old dirtbike like a 125 or something. I dont know if I would mess with em if they seem hard to tune at all.
