jthemmer Posted June 15, 2012 Report Share Posted June 15, 2012 My question is can I use a carb balancing tool (the gauges) with the stock banshee carbs? Where do i hook the hoses up at to find my pressure on these carbs? Quote Link to comment Share on other sites More sharing options...
T_Shee Posted June 15, 2012 Report Share Posted June 15, 2012 U will be measuring vacuum. Not sure what carb tool u are referring to but here is the one a lot of people use. http://www.farmandsandtoys.com/partdetail.asp?partid=59 Quote Link to comment Share on other sites More sharing options...
jthemmer Posted June 15, 2012 Author Report Share Posted June 15, 2012 U will be measuring vacuum. Not sure what carb tool u are referring to but here is the one a lot of people use. http://www.farmandsandtoys.com/partdetail.asp?partid=59 Okay, Mine has two air gauges essentially with vacuum lines that come off of it. Is there anywhere on these carbs that I can hook the vacuum lines up to? Quote Link to comment Share on other sites More sharing options...
Starwriter Posted June 15, 2012 Report Share Posted June 15, 2012 No, there isn't. Quote Link to comment Share on other sites More sharing options...
jthemmer Posted June 19, 2012 Author Report Share Posted June 19, 2012 just for future reference in case anybody does the same as me and wonders where they went wrong, Buy copper mpt fittings and put them in where the boost bottle went, It works! Then you do not have to buy a second carb tool. I did some searching and found this one. Quote Link to comment Share on other sites More sharing options...
