terrible bog.
elev and temp 320 seems big unless you close to sea level. sounds rich to me
elevation is 1000' above sea level and temp 65-80 degrees. mod list is: dune/play port, pro flow filter and adapter (no airbox lid), pro lite pistons, 65mm bore, milled head for pump gas, vf3 reeds, +5 timing, bored stock carbs 28mm, pc pipes.
if your bike runs great a wot then is not the main.. if you can run the quad around 1/4 and below the pilot is not the problem.. everthing in between is the needle!! this is the part of tuning that can be the most frusterating! if you stab the throttle and it does not take it id lower the clip a notch or two! if your not 100% sure if its a lean or a rich problem alway add more fuel first!!
willardwright... would you consider going with pods? i remember i had a bog when using the airbox with no lid on. went to pods and no more bog. no needle change and it cleaned up the bike alot
i cant, i ride a ton of trails and some are really wet and muddy and i just dont want to risk it
the best way to describe it would be just putting around bout 1/4 throttle or below, when i go from 1/4 throttle or below, right to wide open it bogs, then itll wake up and ripp.
If it will pick up and go after the hesitation, it may be lean. the sudden in-rush of air when you go wide-open makes it lean to the point its not making power, then once your jets start flowing and catch up with the air mix its able to pick up and go again. You should always err on the side of rich and go bigger on the jets first. If the problem gets worse, THEN go down. Raise your needle 2 clips and see if it goes totally to shit or if it gets better. Same thing with your air screw. I like to throw it to the complete opposite end of the spectrum with more fuel and see how it reacts. If it gets worse, then you know its a rich condition and you can start to lean it down after that. If it gets better, then you know you are going in the right direction. I've seen a lot of folks burn their shit down because they thought a lean bog was a rich condition.
- Jared
