thinkblue86 Posted June 12, 2012 Report Share Posted June 12, 2012 Hi guys I am just doing mods on my shee and wanted to get new carbs. I heard some where about being able to shave your stock carbs do you guys have any info or comments about that. My shee is a 2001 slight port and polish, shaved head, true and weld crank, advanced timing, t5 pipes, stage 3 clutch let me know what you think out what my best Carb would be if shaving stock ones are not a good idea. Thank you. Quote Link to comment Share on other sites More sharing options...
Dicklez Posted June 12, 2012 Report Share Posted June 12, 2012 There are site sponsers who can open your carbs up. SHOULD be done on a lathe. Not sure how much you can take out of the stockers but I'm pretty sure you can at least goi to 28mm. Shouldnt have any problems with the stockers on your quad. Quote Link to comment Share on other sites More sharing options...
thinkblue86 Posted June 12, 2012 Author Report Share Posted June 12, 2012 Cool thanks bro for the setup I have do you think it would make a difference if I shaved the stocks or got new ones? Or would it be a waste of money? Quote Link to comment Share on other sites More sharing options...
Dicklez Posted June 12, 2012 Report Share Posted June 12, 2012 If your tryin to keep cost down, I would open them up. I was sayin that you can make the stockers work well for your mods. Quote Link to comment Share on other sites More sharing options...
Finch Posted June 12, 2012 Report Share Posted June 12, 2012 id stick with stockers. unless ya feel like losing some bottom. Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted June 13, 2012 Report Share Posted June 13, 2012 I have my stockers bored out to 28mm. It cost me $35 per carb and I have the advantage of being able to buy stock parts for them at any Yamaha dealer if I ever have problems while on a trip. I don't think that Keihins that cost $150 per carb would perform any better than my setup. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted June 13, 2012 Report Share Posted June 13, 2012 a 28 pwk is a far better carb over the stockers. and you can get them for way less then 300.00 a set. most sets go for about 150-200 on ebay. If your going to have your carbs bored.. I wouldn't go over 27.5mm Quote Link to comment Share on other sites More sharing options...
zach45 Posted June 13, 2012 Report Share Posted June 13, 2012 I made the switch to a pwk and they are a far superior carb. Jet changes are so simple. If you wanted 30" I have a set of oko's I would sell. They fit stock intake boots. Pm me if interested Quote Link to comment Share on other sites More sharing options...
willardwright59 Posted June 13, 2012 Report Share Posted June 13, 2012 ive done a few sets. straight bore to 28mm is easiest and takes less time, but ive also done a tapered bore where they start at 28mm and by the time they are into the intake, they are 30mm. works great. jordan dahl has 2 of the sets i straight bored to 28mm. Quote Link to comment Share on other sites More sharing options...
thinkblue86 Posted June 13, 2012 Author Report Share Posted June 13, 2012 ive done a few sets. straight bore to 28mm is easiest and takes less time, but ive also done a tapered bore where they start at 28mm and by the time they are into the intake, they are 30mm. works great. jordan dahl has 2 of the sets i straight bored to 28mm. What do you recommend straight bore 28 Mm our tapered 28 to 30 MN ? can you tell a difference from shaved carbs and non shaved carbs? Quote Link to comment Share on other sites More sharing options...
thinkblue86 Posted June 13, 2012 Author Report Share Posted June 13, 2012 Cool thanks, also sorry about the miss spelling i'm on my phone and it auto corrects. Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted June 13, 2012 Report Share Posted June 13, 2012 ive done a few sets. straight bore to 28mm is easiest and takes less time, but ive also done a tapered bore where they start at 28mm and by the time they are into the intake, they are 30mm. works great. jordan dahl has 2 of the sets i straight bored to 28mm. They look great too. I sold both sets I got from Willard and both people like them a lot so far and they seem to pull better up top then the stock 26mm. I didn't notice a loss on the bottom end while I was jetting it for them so I wouldn't worry much about that low end loss. Jordon Quote Link to comment Share on other sites More sharing options...
MyNameIsMud Posted June 13, 2012 Report Share Posted June 13, 2012 Look into RB DESIGNS they specialize in carb mods a bunch of guys i know have their carbs done by them and they do an awesome job http://rb-designs.com/ Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 13, 2012 Report Share Posted June 13, 2012 ive done a few sets. straight bore to 28mm is easiest and takes less time, but ive also done a tapered bore where they start at 28mm and by the time they are into the intake, they are 30mm. works great. jordan dahl has 2 of the sets i straight bored to 28mm. Like zilla said that is backwards. You want to get a venturi effect. Quote Link to comment Share on other sites More sharing options...
03crawldaddy Posted June 20, 2012 Report Share Posted June 20, 2012 What about the slide? does it still fit right? I have lathe and mill and have been debating on doing it but haven't seen much info on it. Maybe I'll google it. Can anyone post up some pics. Thanks guys Quote Link to comment Share on other sites More sharing options...
