Meanbastard Jr Posted June 12, 2012 Report Share Posted June 12, 2012 I lose less than a half pound in 6 minutes. Its coming from a brand new crank seal.... I really don't wanna have to crack the case again and reseal it for such a minor leak.... is there an acceptable amount of loss or what? Quote Link to comment Share on other sites More sharing options...
mookie Posted June 12, 2012 Report Share Posted June 12, 2012 Fix it now... Prolly jus get worse in time.. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 12, 2012 Report Share Posted June 12, 2012 If your gonna look at it that way just sell the bike. If you're trying to figure out how acceptable a air leak is that you seem to have found easily then I can't imagine how the rest of the bike is. Quote Link to comment Share on other sites More sharing options...
Meanbastard Jr Posted June 12, 2012 Author Report Share Posted June 12, 2012 That's why I was asking to get some advice... anyhow the reason I asked is because the crank seals are brand new and not leaking at the case their leas king around the crank itself. And again the reason I asked because if I take it apart it will probably leak there again due to the fact that its a brand new seal... Quote Link to comment Share on other sites More sharing options...
maskmanLS6 Posted June 12, 2012 Report Share Posted June 12, 2012 That's why I was asking to get some advice... anyhow the reason I asked is because the crank seals are brand new and not leaking at the case their leas king around the crank itself. And again the reason I asked because if I take it apart it will probably leak there again due to the fact that its a brand new seal... Did you put any kinda lube on the crank shaft where the seal goes? if not then you should definately put some on there. The seal will probably do better during and after the leak down test. Quote Link to comment Share on other sites More sharing options...
Meanbastard Jr Posted June 12, 2012 Author Report Share Posted June 12, 2012 Yup I definitely packed some grease around the inside of the seal that touches the crank surface.... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 12, 2012 Report Share Posted June 12, 2012 Yup I definitely packed some grease around the inside of the seal that touches the crank surface.... I can't remember, is that one able to go on both ways? Quote Link to comment Share on other sites More sharing options...
Nightmare Posted June 13, 2012 Report Share Posted June 13, 2012 I lose less than a half pound in 6 minutes. Its coming from a brand new crank seal.... I really don't wanna have to crack the case again and reseal it for such a minor leak.... is there an acceptable amount of loss or what? UNACCEPTABLE Quote Link to comment Share on other sites More sharing options...
Meanbastard Jr Posted June 13, 2012 Author Report Share Posted June 13, 2012 I can't remember, is that one able to go on both ways? Yup I put it on backwards Quote Link to comment Share on other sites More sharing options...
Meanbastard Jr Posted June 13, 2012 Author Report Share Posted June 13, 2012 Just resealed the whole damn thing no leaks thanks guys again!!! Quote Link to comment Share on other sites More sharing options...
