bansheeboi Posted June 11, 2012 Report Share Posted June 11, 2012 What could it be guys I've checked all wired running from lights, now maybe I'm missing something but I don't know what to do? Quote Link to comment Share on other sites More sharing options...
yzrmbsg Posted June 11, 2012 Report Share Posted June 11, 2012 Bad bulbs? If your wiring is good, check your connections, wiring and bulbs. Sent using Tapatalk! Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted June 11, 2012 Report Share Posted June 11, 2012 Have you tried starting the bike? Ok, seriously......Your stator has a separate lead for the lights. You can have power to the ignition, yet still have now power to the lighting system. It may be in the stator. Hope that helps. Quote Link to comment Share on other sites More sharing options...
bansheeboi Posted June 11, 2012 Author Report Share Posted June 11, 2012 Okay all bulbs are changed an yes I have the bike running an still no lights, but will run a check off the wires that come off stator thanks I let you know what I find thanks Quote Link to comment Share on other sites More sharing options...
sheelovesme Posted June 11, 2012 Report Share Posted June 11, 2012 Have you tried starting the bike? Ok, seriously......Your stator has a separate lead for the lights. You can have power to the ignition, yet still have now power to the lighting system. It may be in the stator. Hope that helps. Is this all banshees or certain years Quote Link to comment Share on other sites More sharing options...
yzrmbsg Posted June 12, 2012 Report Share Posted June 12, 2012 Is this all banshees or certain years All Sent using Tapatalk! Quote Link to comment Share on other sites More sharing options...
