Phelps Posted July 20, 2012 Report Share Posted July 20, 2012 Will get pic up tomorrow . Not a stock rod because has K in circle.. black crank webs? if so man i wouldn't risk it with it being a bike on pavement. not that it's worth it anyways, but at least when a quad motor locks up you more than likely wont be getting eat away by asphalt. stock stroke 110 cranks are a dime a dozen even stock ones. hell i have a core i can send you for the shipping cost. let a builder replace the bearings and weld it. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted July 20, 2012 Report Share Posted July 20, 2012 Heres a good answer best buddy ol pal ol friend Nikki lol Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted July 20, 2012 Report Share Posted July 20, 2012 Will get pic up tomorrow . Not a stock rod because has K in circle.. Rods with a "K" and a circle around it, are I believe made by KingRod in Taiwan. Andy from M&M posted some info about them way back. Quote Link to comment Share on other sites More sharing options...
Cheech Posted July 20, 2012 Report Share Posted July 20, 2012 This is what I have with bearing upgrade. I'm very familiar with stock RZ cranks and rods and engine's and have a good stash . RZ forums don't have much if any info on rods used in RZ builds the reason why I don't know. The 4mm is a very popular upgrade and I have never seen a post on rod failure which seems strange . I would imagine the suppliers are pretty much using the same part source? I would think because of less stress but bending on just kick over would negate the less stress theory. http://www.wickedatv.com/DUportal30/home/detail.asp?iData=10366&iCat=280&iChannel=8&nChannel=Products Quote Link to comment Share on other sites More sharing options...
Cheech Posted July 20, 2012 Report Share Posted July 20, 2012 (edited) This is what I have with bearing upgrade. I'm very familiar with stock RZ cranks and rods and engine's and have a good stash . RZ forums don't have much if any info on rods used in RZ builds the reason why I don't know. The 4mm is a very popular upgrade and I have never seen a post on rod failure which seems strange . I would imagine the suppliers are pretty much using the same part source? I would think because of less stress but bending on just kick over would negate the less stress theory. http://www.wickedatv.com/DUportal30/home/detail.asp?iData=10366&iCat=280&iChannel=8&nChannel=Products Pic of unit. Prior to order I did check 8620 steel and from what I could tell used in Wiseco, HotRods , Rockwell of 61 or so also the same. I'm aware steel quality questionable in that neck of woods . I also checked Kingrods have been around a long time but again over there means nada. Was thinking on the 29R/L a min order of say 5k was ordered bad batch steel or manufacture on one or all , they made into pipe line all involved reluctant to pull because of $$$. Just a thought. Edited July 20, 2012 by Cheech Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted July 20, 2012 Report Share Posted July 20, 2012 Where are all these cranks coming from? Quote Link to comment Share on other sites More sharing options...
